Hi
I have recently re-jigged my loft aerials and now I have; DAB aerial into triplexer / FM aerial into triplexer / triplexer out to distribution amplifier VHF input. The amplifier also distributes TV signal which comes from a rooftop aerial connected to the UHF input on the amplifier.
In the main listening room, there is a diplexed TV and FM/DAB wall plate fed from a single cable which comes from the outlet of the distribution amplifier. DAB and FM both have a strong signal but if I connect both the DAB and FM to the tuner/s at the same time the signal drops considerably. I have tried this using a splitter and then feeding a cable to each tuner (I have a receiver with FM only and a DAB / FM tuner). Do I need something other than a splitter at this end - perhaps another triplexer?
Also, why is it not possible to get a wall plate with connections for TV AND FM AND DAB?
Thanks for any advice.
