cyrus X power or 8P to bi-amp
unison
11
I'd appreciate the opinion of others on whether I should choose an X power or an 8P to biamp my XP8 QX. Obviously the X power would be better but I was thinking of putting the £150 saved towards a future PSX-R purchase - which I see are available for £350.
The other part of the system are a CDxTSE, and dali ikon 6 speakers using QED XT400 speaker cable.
My room is not huge
Opinions would be much appreciated
Perhaps people have a different view on an upgrade path?
if you can get a psxr for £350 i would add this first then save up for the x power, its 70wpc matches your amp
Agree. I had the same thoughts but went with the X Power. Excellent investment. I think if I had gone with an 8P I would be thinking... what if....
XPower all the way for me too
My missus had the Cyrus 8vs2 with the 8 power, 8SE CDP and some B&UW CM7 speakers and it sounded great. She was then offered an ex-demo XPower and it made a significant difference to the soundstage and bass depth/punch so it was kept
angelface59 said:
Buy two s/h smart power pluses for 300 quid each!
DO NOT DO THIS
Sorry to bump an old thread but this is for the searchers - someone sent me a SmartPower+ instead of an X Power on Ebay (got a refund) and I was severely disappointed in its performance - the bottom end just isn't there. Get an X Power instead. You also have the benefit of being able to upgrade to another X Power in mono configuration if you want to.
I agree with everyone else, get an X power. You can add PSX-R's later.
Just a thought for the future - Mono x's are a big step up and no more than the cost of X powers with PSX-R's. Of course you will need a Pre Amp...but sooner or later you wiil have to scratch the itch 😉
