Cyrus StreamX and DACXP+ OR streamXP for internet radio?
Thinking of buying a streamer from Cyrus.
Wondering if DACXP+ will make a difference when listening to internet radio (streamX + DACXP+) or if I should rather go for stream XP and xpower.
WinterRacer
34
I had a slightly different Cyrus set up based on XT-SE and DAC-X and ended up selling them both as I couldn't hear any difference between them (at ~£2000) and a Squeeezbox Touch (<£200).
I'm a big fan of the Touch (if you hadn't guessed) : it's unobtrusive, easy to use, has lots of functionality, supports most formats and most importantly sounds great.
It might be worth adding a Squeezebox Touch to your list and then make sure that anything you buy is worth the extra over and above the Touch.
Thanks for the replies,
I will be using mostly internet radio as the amount of songs is so big, and I also have a small library of music. It's easy.
BUt maybe I should look into downloading some good quality stuff. It might worth the effort, as the quality will be much better.
I am new to internet radio. I have just started plugging my computer into my Cyrus straight line. The sound is not great as I am using the headphone output. I would like to improve this, which is not going to be hard!
I quite like these internet radios as, as I said before, there is a limitless variety of songs. I am quite content with this for now.
I will also use the NAS of course.
Thanks guys for your comments.
See you.
