Total newbie looking for advice on sources and speakers
Koeny
Hello! I started my journey three weeks ago when looking at possibly purchasing a soundbar to replace my 25 year old Bose Acoustimas system. Then I learned soundbars are generally inferior to my system and would not improve my tv experience, so I abandoned my intention. But by that point I had learned about speaker brands and audio and I thought: "maybe I can upgrade the audio in my bedroom."
Currently I have a Majority Humboldt radio on which I listen radio daily and often stream music from my pc. This radio is completely fine and I like it but I think I am missing out on experiencing music like it should be experienced. So I am looking to upgrade to a stereo receiver with passive speakers.
My prefered choice of receiver is a brand new Yamaha R-N600A for 550 euro followed by a used Yamaha R-N303 from 2016 for 300 euro (which might be too expensive) and thinking out of the box a Majority Fitzwilliam tuner with a dedicated amplifier. I think a Yamaha A-S301 or A-S501 or a cheaper Fosi or something similar. My knowledge on dedicated amplifiers is inexistant apart for knowing that I need one in case I go for the tuner route.
For speakers I am eyeing from cheapest to expensive Wharfedale 220 (250/pair), Elac Debut 2.0 b5.2 (275/pair), Q Acoustics 3020i (300/pair), Wharfedale 12.1 (350/pair), Elac Debut 3.0 b5.2 (360/pair), Elac Uni-fi UB5 and Elac Uni-fi UB52 (both around 600 euro/pair).
I am looking for your opinion on my possible choices of equipment and maybe suggestions on alternative options.
Thank you!
Juzzie Wuzzie
414
232
19,270
I would have thought a c.500 Sonos Arc would be a solid improvement on what you have (depending on what the TV is feeding it).
I'd suggest considering a WiiM Amp with any of the speakers you list. FWIW - the WiiM Amp has an HDMI-in, so could be used to replace the Bose.
But as AI suggests, if you can audition equipment, all the better.
Links
14
9
Only buy something you can actually audition, especially the speakers.
I think this is the best advice on here. In an ideal world you would test speakers, and amp ( with a good source) actually in the room you are going to set it up in.
Koeny
Would a radio tuner/streamer with an SMSL A300 amp give the same audio quality as an all in one receiver like the RN-600?
Integralista
237
86
370
Thank you!
Hi, how big is your room (bedroom)? Which sources will you listen? Tuner, CD, streamer, vinyl, TV, ...?
good_enough
127
88
18,670
I have a Majority Fitzwilliam and find it satisfactory for Internet radio, which is all I use it for. Its USB input is MP3 only. I find it difficult to recommend as the heart of a system. I paid £80 for it second hand and that works fine for what I use it for but listening critically against my other sources, the sound stage is a little narrower and if I were thinking about a streaming source to match my CD or turntable I'd be looking elsewhere.
I would have thought a streaming amplifier from a reputable source such as one of those from Wiim would do the trick. What country are you in, as you are quoting euro prices? Do you have a New Year sales rush pressing you to decide?
Koeny
I think about 6 x 4 meters or 13 x 20 feet. I use Dab, CD, Bluetooth... I am quite constrained because everything should be able to fit a bookshelf of 32 x 120 cm. So I need relatively small speakers that don't hate being close to a wall, preferably front ported I guess. And I can't really fit a receiver...
I'm in Belgium and I never really considered the Wiim at 400 euro but I like it, my system is getting more expensive by the minute :grinning:
So a Wiim Ultra connected with RCA to an SMSL A300 connected with speaker to my speakers? I added a German Magnat Edelstein and Monitor Audio Silver 50 6g to my possible list.
good_enough
127
88
18,670
The Wiim amp pro would save you a box, and with that SMSL plus a Wiim you are paying for bluetooth twice, so not likely to be the best 'performance per euro' choice. https://www.wiimhome.com/wiimamp/overview
Altogether though I agree with AI ears above, that you really should try to listen to things - especially speakers - before buying. Were you in the UK, I'd recommend a chain here called Richer Sounds who offer both in-store auditions and 'exchange if you don't like it' (and they stock Wiim). Is there not a similar outfit in Belgium?
Koeny
I have a disability so I am not really able to go to one of the very few similar audio shops so I have to audition my devices at home.
