eternaloptimist said:Afraid Steve is NOT right- parituclarly in regard to the newer Cyrus kit (since the 8vs etc).
I have Cyrus pre/power combo which is not in the least "thin weedy and hard" and am not missing anything! Listening with the Audiovectors to female vocal is sublime. I have listened to a lot of gear and love the Cyrus detail.
I suspect you have 2 issues. The main culprit is likely the speakers with the Cyrus gear. Cyrus is very detailed. Speakers that pair well included: Audiovector (I would say that...), Dynaudio (but need lots of power), ATC (ditto), Spendor, PMC, Proac. Are you able to take your speakers to the shop?
The second issue is power. The 6XP is not a particularly powerful amp. I don't know your speakers but unless they are sensitive, you may find the control lacking.
So, overall.... I suggest looking at your speakers.... If you don't want to change them, you may need to move from Cyrus.
I second Eternal's view here; if you want the detail of the Cyrus sound, then newer 8 series stuff (i.e. 8vs2 and cd8x) is probably the minimum standard to go for. I can't vouch for all the speaker brands mentioned apart from the PMCs that sing in my living-room.
Currently listening to: Curtis Mayfield - Superfly
