unsleepable said:We are making fun of this. But I am sure that half of us would actually replace the cable. *biggrin*
The lunatic half.
Vladimir said:And why did Anderson have an identity divorce? *scratch_one-s_head*
steve_1979 said:siderealxxx said:steve_1979 said:You must replace it at once!
I'll be losing sleep lying awake at night worrying about it if you don't. *help*
I'm already losing sleep after my dodgy bathroom installers, so you'd be really helping out taking this on. Frankly Its the least you can do... unless you're also a plumber?
If both the hot and cold pipes are leaking at the same rate that's fine but if one pipe leaks more than the other then we may have a problem.
siderealxxx said:The left speaker is wired to the hot tap and the right speaker to the cold... maybe I've hooked this up wrong?
CnoEvil said:siderealxxx said:The left speaker is wired to the hot tap and the right speaker to the cold... maybe I've hooked this up wrong?
Use an Active crossover and you can't go wrong....otherwise your treble will be too cold and your bass too warm.
Simples.
