Hopefully a simple answer. Just moved house and it is not practical to run cables between my 20 year old amp and speakers.Are there wireless adaptors I can plug into the amp and speakers?
Steve Devine said:Hopefully a simple answer. Just moved house and it is not practical to run cables between my 20 year old amp and speakers.Are there wireless adaptors I can plug into the amp and speakers?
avole said:Bluetooth is a solution. Lots of cheap transmitters/receivers on Amazon.
MajorFubar said:avole said:Bluetooth is a solution. Lots of cheap transmitters/receivers on Amazon.
You can't just plug a BT receiver into a set of speakers, one way or another you still need amplification...
