Connecting normal speakers to a bi wire amp
Bob1753
I am on the verge of buying a pair of Acoustic Solution Av120 speakers but my amp which is Cambridge audio a5 has ports for bi wire speakers. Is there any way for me to connect them up? Thanks
I believe there is only one pair of binding posts on the back of these speakers so just run a single pair speaker wire from the speakers and connect at amp using just the 'Speaker Terminal1' conections ( or whatever they are called). You just connect to the lowermost set of speaker connections on the amp. Completely ignore the other speaker connections.
