i have the nad c375bee connected from variable pre out 2 to fixed in on c272 i have attenuators fitted at the c272 fixed in,i contacted nad to confirm this is correct,they stated i should connect preout 1 of c375bee to c272 input
pre out2 of c375bee should connect to main in of 375bee with original link supplied
i tried what they stated pre out1 of 375 to c272 fixed input removing attenuators and fixing link from main in and pre out 2 on c375
when i tried a disc the sound was muffled and top end was hardly clear at all,i then tried
variable pre out 2 from c375 to variable in of c272 still the same muffled sound
i am now back to preout2 variable c375 to fixed in c272 with attenuators
i was told because the two amps are rated at 150 watts per channel each i should not need the attenuators which makes sense but without them and the way they told me to connect the two the sound is wrong any ideas would be appreciated
