I've connected Marantz PM6005 to the pre-outs of the SR7009 for the rear Atmos speakers in a 7.1.4 setup. How do I get the AV receiver to control the volume of PM6005 so I don't have to individually adjust the volume?
Series1boy said:
have you run audessy setup with the power amp connected, sure this will sort this out for you?
No, Audyssey doesn't do it. I'm having to manually adjust the volume.
CnoEvil said:If the PM6005 doesn't have HT Bipass, there will be 2 volume controls in the mix.
I thought the idea was you set the two channel amp to a reference volume, such as 12 o'clock, run the Audessy to set the correct levels and then leave the two channel amp volume control where it is, so you then don't need to touch the two-channel amp volume again.
bigboss said:CnoEvil said:If the PM6005 doesn't have HT Bipass, there will be 2 volume controls in the mix.
Thanks! I thought the HT bypass is meant only if you want the stereo amplifier to bypass the AV receiver to drive 2 channels for stereo duties.
The_Lhc said:bigboss said:CnoEvil said:If the PM6005 doesn't have HT Bipass, there will be 2 volume controls in the mix.
No, other way around, you connect the pre-outs of the AV receiver to the HT bypass because it bypasses the stereo amp's volume control (it's full volume in effect), so then only the AV receiver's volume control is active. It turns the stereo amp into a power amp in effect.
bigboss said:The_Lhc said:bigboss said:CnoEvil said:If the PM6005 doesn't have HT Bipass, there will be 2 volume controls in the mix.
Ah. It's the PM8005 that has HT bypass but not 6005. Would that be the reason why?
Thanks! I thought the HT bypass is meant only if you want the stereo amplifier to bypass the AV receiver to drive 2 channels for stereo duties. Would the AV receiver control the volume as well?
Thanks! I'll try this tomorrow.CnoEvil said:bigboss said:CnoEvil said:If the PM6005 doesn't have HT Bipass, there will be 2 volume controls in the mix.
It usually would, but I don't see why it wouldn't pass on whatever comes out of the pre-outs.
If the 6005 has no HT Bipass, then you need to pick a volume position on it (say 12 o'clock), and then match it by manually adjusting the other channel volumes on the AVR. Once this has been done, the AVR's volume should control it (just make sure the 6005's volume is set to 12 o'clock).
I think I'm right in this, but wouldn't bet my life on it.
The_Lhc said:you're using it for the rear Atmos channels (I think?), so you don't have that option, you're just using the AV receiver for listening to stereo.
bigboss said:The_Lhc said:you're using it for the rear Atmos channels (I think?), so you don't have that option, you're just using the AV receiver for listening to stereo.
Yes that is correct.
Interestingly, I ran Audyssey again last night, with the stereo amp's volume knob at same 2 o'clock position. It seems that my AVR is now controlling the stereo amp's volume! *unknw*
bigboss said:Now, only if I could work out how to stop Marantz from creating a "pseudo Atmos sound" with even Dolby 5.1 TV programmes!!
