Clean belt residue from my 6 perspex
Seaman
On my 6 perspex I have belt residue on the platter. Any advices,how to clean it without any damage on the platter. Platter is matt black and I think it is MDF.
Seaman
Thank you for answers, alcohol helped and it is clear now. In some parts there are visible stains, looks like by rubbing I "cleaned" black color also. I will respray it wit matt black color and it will be like new.
Or you suggest to let it as it is with kind of patina?
Personally I would let it be. It may be possible that some of the dried paint would get onto the belt and this might cause slippage problems.
Reactions: Seaman
