i assume you mean you have bought the bi wire cable and currently have one end with 2 plugs and the other with 4 and you want to make it 4 and 4? if so yes you can either cut off the 2 plugs as each of the 4 cables are insulated seperatly and reattach 4 plugs. you can either do this yourself or contact chord direct and they will sort for you.
