[quote user="Solomon1"][quote user="lucylondon"]
Hi, I've just bought a pair of Wharfedale Diamond 9.1 speakers which are biwireable, and I'm now looking to upgrade my speaker cable. Looking at the July issue, I see that the Chord Carnival Silver Screen outperforms the QED Silver Anniversary XT, but I'm wondering if buying the QED as a biwired cable would change this? Obviously it's more expensive, but I've found the Chord for £73 (2X4m terminated) and the QED biwire on special offer for £101 (also 2X4m terminated) which seems like a bit of a bargain. Or am I being daft for considering spending £100 on cables when the speakers were only £150? I'm not sure if it's worth the extra £30 to have the speakers biwired. At the moment I'm using an old technics system but I'll probably be getting the fatman itube valve dock in the future. Cheers.
[/quote]
Spending £100 on speakers that cost £150- you've got to be kidding me ! Considering the itube valve dock is only 200 (at superfi) and the cost of your speakers, i'd urge you to buy either the itube or search for Gotham cables on ebay. Or buy some van Damme as suggested. If you later want to improve your system, best buy better speakers. This will give you far more improvement than going the cable route. IMHO cables do make a difference to a system, however not an awful lot and they don't need to be expensive.
[/quote]Hmmm, I did wonder if I was getting a bit carried away with speaker cable costs - although at £4 a metre, the van Damme isn't much cheaper once you've bought the plugs. I need 4 metres of cable for each speaker so it all adds up! Any suggestions for a cheaper option that will give a good enough sound with the Wharfedales and the itube? Will check out Gotham on ebay. Cheers.
