just a quick one which way round do you connect this lead, does the filter end go to the tv? ive pulled all my wiring apart to install new amp and didnt make a note lol
In the spirit of being slightly more helpful, are there not arrows on the cable to indicate the direction? I thought there were, but unfortunately I'm not at home tonight to check mine.
pioneere:
cheers
These cables are meant to be plugged in one way and that is the beige HDMI plug connects to the device you are sending the signal to and the black goes into the source (from).
professorhat:
You are correct, there are handy arrows on the cable
