cheap speakers (temp ones)
hi hope someone can help,
im currently unemployed and my wharfdale laser 150 are giving up the ghost 🙁 not bad for 30+ years of service
so i am looking for a cheap replacement untill i can afford a decent pair
has anyone ever heard of " BENG " if so what are they like (Choice of 3) Beng LB776 or Koda D92F 5 Way Hifi Stereo Speakers 8“ Bass, Koda D858F 5 Way, LTC SP-800 4-way pyramid
details of each follows
LB776 :
3 way speakers with 180W RMS
Impedance: 6 to 8 Ohm
Frequency range: 20 Hz to 20 kHz
Koda D92F:
2 x 60W RMS @ 4ohms
5 Way technology with 20cm/8” bass drivers
3 mid-range speakers and 1 tweeter
Frequency range: 50 Hz to 20 kHz
Sensitivity: 87 dB +/- 2 dB
Impedance: 4 Ohm
Koda D858F:
180 Watts RMS each (400 Watts Max) – per speaker
Bass reflex
Sensitivity: 89 dB +/- 2 dB
Impedance: 4 Oh
Diameter Tweeter: 2.8 cm
Diameter Bass speaker: 18cm each
Diameter Mid-tone speaker: 11cm each
LTC SP-800:
4-way design with 2 woofers (20 and 25cm), midrange (13cm) and a tweeter (2.5 cm)
Bass Reflex
Frequency response: 20Hz to 20 kHz
SPL: 89dB Impedance: 6 ohms
these are only a temporary soloutiin will buy better ones when found a job
Many thanks
reply to please
Email admin@cocteau.plus.com
I'll admit that the Beng stuff looks the part but I'm suspicious of em anyway. Have a look at richer sounds for something proven at a bargain price. Size isn't everything dude.
If its only temp why not go 2nd hand? You will have a huge selection and also have the advantage of recouping most of your costs when you choose to sell on.
