I look at people's signatures on here with great interest, some seemingly appear to have an almost never ending list of components. One that especially springs to mind is Gazzips, probably because I've been following his thread on room correction. Again looking at his chain of components I was left wondering about the order of these and the commands sent down the chain eventually to the speakers, which has priority and how is this set? Dacs in particular spring to mind, so many units have them inbuilt these days, obviously these vary in terms of quality and implimentation. So my question is how is it decided on what DAC has the final say at the output entering the speakers?
My own system was intended to be relatively simple, active speakers being fed (originally) from a Yamaha WCX-50 (now deceased and replaced) and a Phono amp feeding the turntable signal. My speakers have inbuilt DAC and pre-amp section which if I'm honest I want to bypass. Things have recently changed, Oppo HA-1 is arriving today (hopefully this one works, see other thread), I hope to be implimenting a cheap version of Dirac Live (when I purchse the software upgrade) The Oppo HA-1, Minidsp 2x4HD and speakers all contain a DAC, plus I've two preamp sections in my chain... The plan was to have the Oppo outputting (rca) to the Minidsp and then in turn that connected by it's four rca outputs to the each stereo speaker (subs included) I'm thinking as the MInidsp is connected to speakers via rca then that bypasses the digital section of my speakers innards but my confusion lies in the two DACs in the Oppo and Minidsp. Apparent the MInidsp operates some form of streaming function (again I've not used this yet, still boxed, just taken some basic mic readings) So if used in this manner would this kick start the MIniddsp's own DAC being the last component before reaching the speakers? I'm assuming if I use rac outputs from the oppo into the Minidsp the Oppo's DAC will be the all conquering and definitive DAC at the final output stage just passing through the Minidsp? If however I feed the Minidsp a digital connection via the Toslink, who rules the roost then? Basically I want the Oppo as my primary Pre-amp, the Minidsp to solely work it's correction magic whilst feeding the DM10's and bypassing any of their internal electrics.
My system is not set up properly yet, as I'm awaiting the delivery of the Oppo today, so my mind is tryig to sort this out prior to set up. Can i just add at present I'm heavily medicated, for pain relief and not thinking clearly so if this rather long winded post has an obvious answer I apologise... I hope some of the above makes some kind of sense.
Yours, of unclear and totally confused mind. LL
