Hi everyone i have been lurking on this forum a good fews years (only just registered) and appriciate any knowledge / help you can provide. So thanks in advance
My system and problem.
I have built a 5.0 system (NO SUB) around Q Accustics3000 speakers, 3020 fronts 3090 centre and 3010 for rears. I purchased 2 weeks ago a Yamaha RXA-860 receiver and using Cambridge Audio sympony 200 speaker cable all round. Speakers have a good 30 hours use.
I am generally happy with the system apart from the CENTRE SPEAKER VOCALS that i am experiencing at present. Now this is my very first system and appriciate the AVR is not a basic amp but i am generally technically minded and have played about with various features and made some difference to the intial set up after running YPAO calibration .
After initial calibration and a little fiddling I felt something just was not right , and wounder why PCM displayed and just thought there something wrong. I am now running bitstream from SONY 7200 and use Audioquest Pearl HDMI and noticied an uplift in vocals straight away. I am running the decoder in STRAIGHT and to me it sounds identicle to NEO 6 and better then the other decoder options.
MY PROBLEM.
I run NATURAL sound option is best but felt the vocals a bit flat and had a base /deepness to them which to me seemed a bit unnatural but the main concern was that voices sounded very flat with little expression. (as though voices are almost coming from behind the TV)
I have adjusted centre speaker EQ by dropping the bass a bit and increasing the EQ from approx the mid to mid high range and i have got some improvement. I have then discovered seperatly the option to specifically up the VOCAL lift and find 1-2 to help.
With everythng i have mentioned above there is a notible improvement in the vocals, but still feel could be a bit better.
1 thing i have noticed is that the centre possibly sounds better after 20-30 mins warm up. I may be crazy i dont know.
I would give it 7 / 10 for the vocals but still feel it can be more expresive. PLEASE HELP
MY PROBLEM.
