- Aug 10, 2019
- 2,556
- 5
- 0
Testing with some brand new hi end cardas cables.
Very stupidly, I plugged one interconnect from my cd player into the MC bus socket of the pre amp instead of the cd input of the pre amp. Clever i know!
Compounding this, I then took the second output and connected it to the "chain output" of my monoblock, instead of the speaker input.
Anyhow, then I turned it all on, as you do. Some VERY loud popping noises from the speakers and the wrongly connected monoblock turned off.
Having eventually figured out what i did wrong, luckily everything "APPEARS" to be still working properly... i put my ear up to the woofers and tweeters on my speakers and there was still sound coming out, and I couldnt noticeably tell of any degredation in sound quality.
HOWEVER, there was a funny smell emanating from the hi fi area... i was immediately concerned that i had burned out something in the monoblock or the pre, but after some time i can say that the smell comes from the new cables at the input connector.
So i am hoping that nothing is damaged and sometimes new cables smell that way (as it was their very first use, i have no way to compare), maybe because the connectors had a very small amount of cleaning oil on them or something when they left the factory.
What do you guys think????
