Can the ipod touch connect wirelessly to your home network
Gerrardasnails
295
matengawhat:Can the ipod touch connect wirelessly to your home network to play music straight off itunes?
I doubt it because it's a well known issue that you can't take a digital feed from an ipod. I might be wrong though.
matengawhat
695
15
18,895
i've got a wadia so thats not a problem - i know you can use it to control i tunes as a remote with th squeezbox but just wondered if it could play them through its internal dac or more importantly output the raw digital information
rod1429
6
Why not try an Ariport Express - approx £80 & will stream itunes to your hifi via a 3.5mm to rca cable or toslink(with 3.5 adaptor) to your DAC.
You can then use the remote app on the touch to control the Itunes & select device or computer etc.
John Duncan
It can, yes. I use the free 'Airfoil Speakers Touch' app because I already have Airfoil but I think also that 'Simplify Media' does the same sort of thing without the airfoil client, so is much cheaper, but I haven't tried it. Though for £3.49 it's probably worth a punt for you...
EDIT - though having just started streaming Spotify to my iPod, getting a lot of breakup (my wireless network is being trunky lately)
