Can I use a Sub with an arcam alpha 8?
kingnothing83
56
I have just bought a wharfedale sw250 sub with line level and speaker level inputs. This will be used with my av amp when i buy it, but as i'll not be getting it for a month or so, can i use it with my arcam alpha 8 amp? If so how do I wire it up?
cheers
simon
kingnothing83
56
http://img524c.imageshack.us/img524/2572/arcam11cz9.jpg
that is the back of an alpha 8p (only image i could find right now) but i have the same "sp1 direct" "sp2 switched" connections on the back of mine - i'll give it a go tonight but do you think it'll work or does the amp just let you switch between 2 sets of speakers, not power them both together?
cheers
fatboyslimfast
158
Basically, Direct is permanently on, and Switched means the speakers get muted when you put a pair of headphones in.
So, as long as you don't put headphones in, you should be fine using both sets.
Big Chris
400
Actually. I think it's SP1 that are non-switchable, but will still mute with headphones. SP2 are switched, in that there's a button on the amp that says SP2. This will switch the SP2 on and off.
I could be wrong, but that's how my Arcam amp works.
Connecting the sub to the switched (SP2) connections is a good idea, as you can turn it on or off in seconds, with no effort.
