landco
Is it a great day for this guy to think, do he need such "tight" headphones at home? Or should we leave this artifact of the past - in the past?The Beyerdynamic DT 1990 Pro needs 250-Ohm to run,
Votre langage cryptique me vexe, mais peut-être que je suis juste idiot. S'il vous plaît, pourriez-vous m'expliquer gentiment que la vieillesse me vieillit. Merci 🙂Is it a great day for this guy to think, do he need such "tight" headphones at home? Or should we leave this artifact of the past - in the past?
It’s about 250 ohms being too much and too inconvenient, what’s the point if you can’t buy a nice headset more than 30 ohms?Votre langage cryptique me vexe, mais peut-être que je suis juste idiot. S'il vous plaît, pourriez-vous m'expliquer gentiment que la vieillesse me vieillit. Merci 🙂
I don't know man, I was asking, maybe there's 30 ohms version of the DT 1990?It’s about 250 ohms being too much and too inconvenient, what’s the point if you can’t buy a nice headset more than 30 ohms?
Well not for the subject of this thread.It’s about 250 ohms being too much and too inconvenient
For a quality audition enough to buy headphones no more than 30 ohm. No point buying a CA.Well not for the subject of this thread.
CA recommend headphones of up to 600 ohms for the 200M.
No more than 30 ohms?For a quality audition enough to buy headphones no more than 30 ohm. No point buying a CA.
Headphones 250, 300, 600 ohm - this is atavism, a relic of the past. It is inconvenient. Why do you need this? It is better to use 30 ohm headphones, you will not need to buy an amplifier.No more than 30 ohms?
Stick to that rule and you'll be excluding a hell of a lot of headphone models from your audition.
With such a limited choice, it might indeed be best to forget the idea of any headphone amp.
If I can interject here, there are benefits for both. Higher Ohms are largely used in professional studios, where high sound levels are recorded, high Ohms prevents the headphone from overloading, 30 Ohms isn't going to cut it in a professional studio. Check this link.Headphones 250, 300, 600 ohm - this is atavism, a relic of the past. It is inconvenient. Why do you need this? It is better to use 30 ohm headphones, you will not need to buy an amplifier.
Most audiophiles do not know that high-resistance headphones were relevant 30, 40 years ago, when the audio path was imperfect, with a low signal/noise ratio. Now this problem is irrelevant, but many (including you) continue to buy it.
usa.1more.com
To put it simply, higher quality sound.Headphones 250, 300, 600 ohm - this is atavism, a relic of the past. It is inconvenient. Why do you need this?
This forum discusses home audio, so thank you for your comment, but it is not relevant to the topic.If I can interject here, there are benefits for both. Higher Ohms are largely used in professional studios, where high sound levels are recorded, high Ohms prevents the headphone for overloading. Check this link.
Happy to assist but if you read between the lines, what I was alluding to, if you pair this with appropriate head amplifier you will experience better sound quality from your high Ohm headset!This forum discusses home audio, so thank you for your comment, but it is not relevant to the topic.
It’s about overload, are you often overloaded listening to music at home? It has nothing to do with sound quality. Low resistance headphones sound just as good as high headphones.Happy to assist but if you read between the lines, what I was alluding to, if you pair this with appropriate head amplifier you will experience better sound quality from your high Ohm headset!
If you only want to listen your music on your mobile or DAP, 30 or less Ohm headphones should suffice.
It isn't relic at all, there's a purpose for both low and high Ohms headsets.
I don't 'buy' anything 🙂.Most audiophiles do not know that high-resistance headphones were relevant 30, 40 years ago, when the audio path was imperfect, with a low signal/noise ratio. Now this problem is irrelevant, but many (including you) continue to buy it.
Sound quality is much to do with the quality components used but it's fair to assume manufacturers like Beyer make them this way because there's a specific market for them both in the studio and home. You can't just go on a rant and call it an 'artifact of the past' and it's also naive to assume that manufacturers are daft, they put far more research into this, that surpasses any of the rhetoric on this thread.It’s about overload, are you often overloaded listening to music at home? It has nothing to do with sound quality. Low resistance headphones sound just as good as high headphones.
My headphones are connected to the DAC's headphone output and the DAC is connected to my phone via USB.The Beyerdynamic DT 1990 Pro needs 250-Ohm to run, it's great your Android phone is taming the beast or are you using a headphone dongle with your Android?
Ah that makes perfect sense, Thanks for clarifying 😊My headphones are connected to the DAC's headphone output and the DAC is connected to my phone via USB.
