Cambridge Audio Azur 840E or ATC CA2 MkII Pre-Amplifier?
I'm looking at buying a new preamp for one of my systems I have narrowed it down to two preamps.
They are both within my budget a Cambridge Audio Azur 840E or ATC CA2 MkII Pre-Amplifier.
Does anyone know which would be the most neutral and detailed amp?
hsv334:I'm looking at buying a new preamp for one of my systems I have narrowed it down to two preamps.
Hi hsv334
I've not heard the Azur 840E however i can certainly vouch for the CA2's quality. ATC have designed the CA2 MK2 to have a level of transparency and robust output stages so that it can ultimately be used with their Professional amplification and studio monitors such as the P4 mono's and SCM300ASL's. Fwiw, i feel the CA2 MK2 achieves around 75% of the performance of ATC's reference SCA2 pre amplifier at a quarter of the price!
Btw, what source component(s), power amp(s)/speakers will you be using please?
All the best
Rick @ Musicraft
I using NS-1000M speakers, B-2x Dual Mono Power Amp, and hi end Yamaha CD player.
hsv334:I using NS-1000M speakers, B-2x Dual Mono Power Amp, and hi end Yamaha CD player.
Hi hsv334
Thanks for your reply.
NS-1000's are excellent speakers although i've not heard the B-2x power amp. If possible please have a listen to the CA2 MK2 and the Azur 840E with your components.
All the best
Rick @ Musicraft
MUSICRAFT:
Hi hsv334
All the best
Rick @ Musicraft
The problem is I am in a situation where I can't test either of them in my system I live in Australia and I am to far away from the dealers for that.
The Yamaha B-2x was designed to work with the NS-1000m I will only be buying one the amps mentioned if I can't find a Yamaha C-2x preamp
Pete
hsv334:MUSICRAFT:
Hi hsv334
All the best
Rick @ Musicraft
Pete
Hi Pete
If you haven't already done so then it might be worth asking the dealers if it is possible for them to send you the units for a trial.
All the best
Rick @ Musicraft
