- Aug 10, 2019
- 2,556
- 5
- 0
I've recently purchased a virtually un-used Pro-ject Debut 2 and its brilliant (for me as a first turnatble anyway).
It includes the OM5 but I would like to replace it.
But Im very unsure about what is the best budget replacement and most suitable for the Debut 2.
I have looked at the 2M Red and Blue, but is there much difference between them...sound quality wise?
Or would it be best to just replace the stylus with a OM20 or OM30?
I mostly listen to hard rock, metal music and 70s rock/pop (if that makes any difference)
Any suggestions to what is the best buy would be greatly appreciated because i'm stumped!
Thanks 🙂
Thanks 🙂
