Budget speaker cable advice please
Bradnett
Hello , quick bit of advice please.....
Will I get away with Qed 42 strand speaker cable with two lengths (1 x 16m & 1 x 10m) and still get a decent sound out of it. Need a cable easy to hide and monies a bit tight!
Denon Ceol RCD-N8 & Q Acoustic 3010 Speakers
Thanks in advance
All you need is 2.5mm sq OFC multistrand, which can be picked up from Maplin, B & Q etc.
You may also like to do a search on WHF as there are quite a number of cable threads.
Hope this helps
Bill
Thanks Bill , so you don't rate the QED stuff then as I saw that quite cheap somewhere anyway.
The QED 42 has a cross sectional area of 0.75mm, you want something that's 2.5mm and not expensive, you don't need to pay silly money for a cable. So look at cross sectional area in the specs, ignore any other marketing you see adertising a speaker cable.
A member of this forum recently bought some terminated Van Damme, if you're wanting to keep the costs down but it unterminated.
Maplins stock Van Damme Blue, its about £3 pm for 2.5mm that will do fine. The Van Damme OFC is about £5 pm and some say is better, I would go with those rather than hifi brands.
Thanks in advance
There is nothing wrong with QED 42 strand. It is however a bit thin for your application (0.75mm sq), particularly for the 16M run. For that length, aim for a cable with a cross sectional area of at least 2.5mm sq.
QED 79 strand will fit the bill, but to be honest, there is no need to pay up for a 'hifi' brand, any 2.5mm sq cable will do.
The 2.5mm sq Van Damme cable recommended above would be fine, but you are paying for a brand name, and for an external sheath for the cable which is great if you are using the cable on the road, but performs no function I can see in a domestic environment. It is also bulky and something else to have to strip when you are making off the cable ends.
If money is tight, I have recommended a cable from TLC a number of times (TLC are an electrical factor, they have branches all over the place). Part number is CA SPEAK79 - as far as I can tell it is identical to QED 79 strand and costs about 59p + VAT a metre for a cut length.
Bradnett, that seems like excellent value must keep them in mind if I'm looking to get more cable in the future.
On the audiovisualonline website there are a couple of types of fisual ofc 2.5mm speaker cables on offer for £1.95 and £2.20 per metre.
Thanks in advance
Looks good value. Makes me wonder about the prices we do pay.
Some great suggestions here already but just to add that if you're nowhere near a maplins or any other 'physical' retailer that sells cable, don't rule-out ebay for some good bargains...going rate there seems to be about £12-£15 for 20m of 2.5mil multistrand.
rainsoothe said:
hi.
From what I understood from some cable discussions, you should get equal lengths - someone with more knowledge correct me if I'm wrong.
QED 79 strand (2.5mm sq) has a loop resistance of 0.016 ohms/metre. You can live with quite a few metres of mismatch in length before the differences in resistance between the two lengths of cable become significant. Tough to say exactly where it would become audible - depends on all sorts of things. In an ideal world try to keep them the same, but don't sweat a few metres here and there.
There's always 1 idiot, that 1 star review is the only 1 star review in 2 years. It looks legit to me? Does anyone else mention it being thinner than advertised?
Yes read the 2 star review, which also suggests its not even copper.
I think you're right! The description, as far as I can see on mobile doesn't even state what it's made of 🙂
Bradnett said:
Ended up going for the 79 strand TLC 2.5mm , hopefully that will do the job!
Good move, I dont think you will be dissapointed.
If you get a chance, can you report back on how you got on with the cable? I sometimes feel like a voice in the wilderness on here when it comes to recommending cables that cost less than the average weekly wage.
This. I use Van Damme Blue, works a treat. You can get a 10m reel of unbranded 2.5mm OFC from Digitalis Direct for about £6 delivered. You know it makes sense. I got some a few years back and it replaced some Audioquest Type IV.
