I need some advice for a stereo amplifier and speakers. Basically, I moved from my previous apartment and had to leave behind my amplifier and speakers. I've got a chromecast audio and a Schiit Modi 2 uber that are (were) connected by toslink, and I usually stream music using Plex/Tidal etc. Therefore, the DAC and connectivity are not really important for me in an amplifier, all I care about is the sound quality. I've seen this thread which is kind of similar to my requirments, however that specific user got more money and decided on higher-tier equipment which sadly is not an option for me.
If it matters, I usually listen to progressive (Porcupine tree, Steven Wilson, Tool, Soen etc.), a bit of metal (only older Opeth basically), some older grunge music (Soundgarden, AIC etc) other older stuff (Dire Straits), and you could probably find me listening a bit of instrumental music (Andy Timmons). This isn't a very exhaustive list, but hopefully it gives some kind of picture of what I listen to if that's important.
Sadly, where I live things cost quite a bit more, and there isn't a huge selection of amplifiers. Just to give you guys an idea how much things costs around here, the Cambridge Audio CXA60 costs around 1350$. The Marantz PM6006 is 980$. I assume that with some haggling I could get my equipment for around 250$-350$ less. For example, I was offered the Monitor Audio Bronze 2+PM5005 for ~1300$ instead of their ~1665$ "list" price (separately, they cost 715$ USD and 950$ respectively) with almost minimal haggling.
I'll obviously go and test things myself, but I want to get a picture of what I want to ask for. Basically, looking through the lists on this site what I see usually recommended is the Marantz PM6006/5, I haven't seen many reviews for the PM5005 here but I assume that it's also a a decept option as I already have a DAC. I've also seen the Nad D 3020 recommended, but for some reason I have a feeling that the Marantz is a better solution for sound quality alone, as I don't really need the connectivity side. I've seen some other companies like Rega and Rotel, but they usually cost too much (or are recommended less than the above).
For speakers, it looks like the Monitor Audio Bronze 2 and Dali Zensor 3 are the two obvious candidates and cost about the same.
So - is there anything else that's newer or just something that I missed that I should listen to? Am I missing something and is there a different/better way to setup my stuff?
Thanks!
Thanks!
