Hey Up, its you again.
I wonder, can you see daylight?
	For some one who has his head so far up his ar.. that he has formed such posted views again, and again, and again without using his ears to arrive at his conclusions posted. Or are you just gunning for a fight?
The 'current' loading on this BT equipment is mainly dictated by the mains fuse, which is applied to the original use put. Therefore one could find a even a 2A fuse in the plug!
Obviously not suited to a higher amp loading of Hi Fi equipment. The design of these power units with the various rated transformers, chokes, capacitors, circuit breakers was done for reliability and to protect whatever came down the mains, including lightening strikes!
These units are so over engineered they just do there job, and if a big surge comes down the mains they will shut off, reset, then carry on as before!
	So don't overload them past 13A peak, just buy another one and split the load!
As to the difference they make, buy one, along with a BIG slice of humble pie and enjoy your musical experience.
Regards etc
