Denmark, i had to wait for next month if i wanted a pair of wharfedale evo 4.1, what can i else get, tannoy revolution xt mini was alot cheaper, and had single point source like kef q and ls50. Sound comming from the same point, time alignement and other advantage having sound comming from the same point.
88 db 3 db higher than the d7 (85db) not a problem i can still play loud enough with my modest amp and it still sounds good.
Asked about the bass and the d7 has a more full bodied sound, not that 0.5" should make a huge difference.(i think it does)
Do you have a b-stock in white, yes we have, i asked again just about when they came and collected the hifi for delivery to customers and he had printed a label for shipping,delivery, i only knew they hade a b stock d7 in black and d11 in white, think he had alot to ship since there was antoher 8 customers he had to answer, make shure they got what they wanted.
Live chat we don't have a white pair so i wil sent you a new pair, is that okay, as long as they sound good, that's what matters, they do sound really good.
The bass is surprisingly good, deep and punchy it almost breaks the laws of phyiscs, that good is it, my amp also enhances the bass a little, it's not neutral (amp).
Got them today and i was a little afraid they would be thin and bright sounding
The highs and also the lows from my amp is a bit forward so the sound would have a bit of a v shape, the highs sound good not to much as some Dali, B&W and other speakers can have, much bigger soundstage than the size would indicate, the bass , i can't belive how much bass i can get from such a small speaker edm is no problem, is loud any problem, no, even with edm (not those horrible bass bosted songs) is no problem playing loud with my amp (pc, nearfield)
2x30 watt in 8 ohm they are rated at 85db 8ohm and 20-125watt and just under 70hz -3db
Just don't expect hard style edm with 2x50 watt and up, with most small speaker don't use a to bright sounding system, floorstand speakers can more easily with there bigger bass handle a little brightness form a system than the same speaker in the bookshelf version.
