Frank Harvey
Unregistered User said:as the title says i've £1000 to spend on bookshelf speakers.
first of all my room is rather small (3mx3m) and the speakers will be sitting close to me (on or above my desk, so less than 1m away)
i've no amp because i'm not sure whether to go for 2 speakers or 2 speakers + a subwoofer.
the sound i'm looking for:
mids, i want life like instruments and vocals, I can't stand recessed mids.
treble, my ears don't tolerate emphasized treble, must be neutral and i don't mind if it was slighly recessed.
soundstage, i want it to be true to recording (i find a lot of headphones like K702, HD800 have "big" soundstage, trouble it stays "big" no matter what genre or song 🙁),
bass, i want quick, detailed bass, but still fairly powerful. since these would be bookshelf speakers (and i could possibly add a subwoofer) i'm not sure whether to look for speakers with "best" bass or settle for something with decent bass and great mids, etc. thoughts ?
i can only compare my idea of perfect sound to my current set of headphones, Audeze LCD-2, if its any help
any help would be very welcome, thanks for reading.
One thing to take into account is your position in relation to your intended speakers. If your ears are in line with the HF units that's all well and good, but if they're going to be situated higher, the sound and soundstage of a lot of speakers can change drastically if you drop yourself below HF eye line.
The other issue is that because you'll be sitting so close to the speakers, you're more likely to be aware of the HF not coming from the same place as the mid/bass. This can be quite off putting, and again, the sound of the speaker can change depending on your position in relation to each of the two drivers.
Amongst all this 'activity' (
At £600, they leave plenty of change to pick up a good amp to get the most out of them, whether that be new or used. They'd kick ass with a used, nicely warmed up Audioab 8000A that can be had for £150, or an Arcam Alpha 10. If you want to add a sub, these amps have pre-outs, so you could add something like the sealed SVS SB12. All this would still keep you around £1500.
It's a case of having a few auditions and seeing what you like the sound of 🙂
