duaplex said:How much are you looking to spend? Could you give us an idea of what you are looking for in a bluray player? Also details of setup please, is this going through an AV receiver?
gezpen said:I will use scart cable to connect to TV.
Son_of_SJ said:gezpen said:I will use scart cable to connect to TV.
No you won't. Most Blu-Ray players don't have Scart outputs. If your television has an HDMI input, and I think it has but I'm not sure, then you need an HDMI cable from the Blu-Ray player to the TV, the HDMI cable will carry sound and picture.
greycounciller said:I'm currently using the Pioneer BDP 450 with this TV and on the whole it works very well.
The player only has HDMI outputs, but since I don't use it for 3D, it won't be an issue.
Picture quality is good and sound thru AV amp is very good.
There are many cheaper alternatives available and I'm sure many will fit the bill.
What HiFi has many good reviews you can use add a guide.
bigboss said:Make sure you demo the players you shortlist. As your TV is HD ready only (720p & not 1080p), you may find that cheaper players will upscale just as good.
gezpen said:Does DAC only improve the audio?
