Not sure where to post this really but am having an old issue and I'm wondering if anyone else has had similar!
In having a fairly new but thoroughly run-in Plasma I've been attempting calibration (will post thoroughly on this at some point when work quietens down!) - of course I like to use test material to check the results. I haven't got masses of Blu-Rays really so Casino Royale is probably still my best all-round reference point, but there's a problem, it won't play. Now this is a fairly standard problem as disc/player issues go but it's left me confused...
I have an original PS3 as my Blu-Ray player, it has always worked perfectly and plays every other disk with no problem. The Casino Royale disc was my first Blu-Ray and used to play fine - now the PS3 doesn't even register it when I put it in, literally - there's not even a whir from the drive. Obviously I decided to check the disc and here's where confusion sets in - it's perfect! Like a mirror. No dust, no smudges and certainly no scratches.
Anyone have any ideas what's going on? Had similar problems? I'm a little concerned that an apparently perfect disc won't register, especially since all the other discs work fine (as did this one originally) - will others develop the same problem? Of course the simplest solution is to try it somewhere else - but I always forget to take it to mate's places and I'm on the forum now so figured this would be as good a place as any to start! [] Hardly a life-threatening issue I know!
*I may have posted similar to this in the past but I can't remember what forum that was on []
*also meant to post this in the "Home Cinema", not TV forum! []
