Thought The Beachboys had sorted the 'bad vibrations' issue way back.
shadders said:Hi,
I had a quick read of the forum post - read the ASA details and looked at their (Black Ravioli) web site.
The advert claimed that the product eliminates bad vibrations - i would assume all vibrations are eliminated.
On the forum, someone has stated that nuclear submarine material is used ?.
What would work just as good is an old sock filled with sand. The reason perhaps vibration elimination is used on subs is that they are then less detectable using passive sonar. The reason subs do not use old socks filled with sand is that the material needs to be light, neutral density (will not sink or float), and not affected by water - else the submarine would sink.
So rather than pay £200 for these products, buy some sand from B&Q, fill up a few socks and it should make a difference.
Regards,
Shadders.
