:wall:
Hi all,
Im looking at the monitor audio silver sxfx surrounds to use in my 5.1 set up. I'm just a bit confused as to their positioning. They can be switched between bipole to dipole for flexibility. Some say side walls others say rear walls. My listening position is close to the rear wall about a foot away. Not sure if that makes a difference to their placement.
Any tips or advise would be most welcomed.…
Hi all,
