Thompsonuxb
- Feb 19, 2012
- 125
- 0
- 0
davedotco said:Glacialpath said:TB303 said:This is what the backplate of the amp looks like, if it helps:
http://classeaudio.com/images-product/CAP-2100_B_LG.jpg
What do you think?
Thanks!
Hello again. I wish I had actually looked at your amp before I posted last time. Basically if you use both sets of binding posts on the back of the amp for both speakers you will be Bi-Amping as your Classe is a pre and power amp in one unit. No need to go and buy a second amp. Just the right kind of matching speaker cable. Connect the Pre amp bonding posts (i imagine the top pair are the pre amp ones as I couldn't find a clear description in the user manual. Contact Classe for clarification) to the + and - of the tweeter (or High) and the other pair to the + and - of the driver (or Low.....obiously 😉)
Which input connections are you using to connect your source and what is your source? Also what kind of music are you mostly listening to?
Te Cable Madman (Glacialpath) :rockout:
Totally incorrect....... :wall:
The CAP2100 is a straightforward 100wpc integrated amplifier. It can not bi-amp anything by itself.
The two sets of output terminals were included at the request of their favourite cable company, to allow bi-wireing and increase sales of speaker cables.
Otherwise it is a rather nice if somewhat pricy integrated amplifier.
the bit in bold - expand pls.
Both sides have the same output - connect both pairs and you lose nothing in performance.
What you do though is provide each driver with an uncompromised signal if the amp is used in this way. How does that differ from using 2 power amps to drive each speaker?
In fact explain how bi-amping can make a difference and configuring a single amp with provision for 2 pairs of speakers in this way won't?
