I'm no expert and I've never tried bi-amping, but here's my understanding for what it's worth. Many pre-amps have 2 sets of pre-out phone connections. On my pre-amp, there are 2 sets of phono outs for connecting to amps. Also, on my pre-amp, 1 of the outputs has a variable control that would allow a person to dial in the right power level for a second amp if it wasn't identical to the first amp.
The speakers are a simple matter. You just remove the factory metal bar connecting the two sets of binding posts. Then you connect Amp 1 to the bottom speaker binding posts, and amp 2 to the top set of speaker binding posts.
I'm not positive, but I suspect that if you only have 1 set of pre-amp outputs, you could use a 1 to 2 splitter cable to connect to 2 amps from a single pre-amp out. But obviously have 2 sets of pre-amp outs is a much better solution.
If you do have 2 sets of pre-amp outputs, but they are both fixed (no way to dial one up or down to match the other), then you have 2 options:
1. Use identical amplifiers. This is best anyway.
2. Buy an amp that has a dial to regulate the phono input signal. Some amps have this feature.
Now, all this makes bi-amping sound very complicated. It's not really. The simple solution is buy two identical amps and use the 2 fixed pre-amp outs to hook to each amp. Then hook each amp up to one single set of binding posts on the speakers. That's the simple approach.
Are you thinking about buying a second 909?
