Better Spekers than Triangle Borea BR03
matthewpianist
561
668
1,770
Pefect advice! If you like the general sound signature of the AXA25 going to Marantz is not a good idea. Buy the C326BEE if you can afford it, your speakers have a lot of potential.
I agree with the NAD recommendation, but they no longer make the C326BEE, so that would have to be a secondhand purchase. The C316BEE v2 is very much on a par.
dommaku2
44
12
45
OK - what I gather is:
1. Triangle have potential
2. NAD 316BEE V2 is best candidate
one extra question:
I listened and compared Cambridge AXA25 with (£600) Audiolab 6000A for me I could not tell much difference. I switched sound back and forth but they seemed similar. In contrast when I added DAC magic 100 to my current set up I heard significant difference as compared to Mac Book minijack as source.
- Can NAD 316BEE v2 (£300) really be much better than Cambridge AXA 25 (£250)?
To add some taste info:
- I used to have bigger flat and there Onkyo 8150 + Canton GLE 470 - this is my baseline for decent sound that I am after (or better) that I can't get now from my set up.
- Pioneer A-10K Amp sounded awful
npxavar
329
113
570
The Audiolab 6000a includes an unshielded digital section. Beacause the quality of the digital section is otherwise high (plus a few extra watts in driving power) this makes for a more expensive amp, but with a less clear sound. All analogue rules!
npxavar
329
113
570
Having said that, you may be missing the bass extension which makes for a fuller sound. Maybe you need to look into 6+ inch speakers that the AXA25 can drive. Hi-fi can be tricky.
Reactions: gasolin
npxavar
329
113
570
Thanks which model have 6 inch ?
Almost every well-known company has one at your price range. What you have is 6,5. However it is not only about sensitivity/efficiency.
You have to audition. It is hit or miss for this kind of power rating and price.
npxavar
329
113
570
This site has paired the Triangle Borea BR03 with the Cambridge Audio CXA61 for its review.
Comments on bass for the reviews of Audiolab 6000A and the CXA61
Audiolab 6000A: "bass is pulled taut"
CXA61: "thumping basslines", "digs up low level details"
dommaku2
44
12
45
I noticed - on really low volume "singer" is louder in one speaker.
Just to be sure I bought new pair of cables with banana plugs.
I tried again problem persist.
I switched plugs different way round. Problem persist in another speaker.
So the issue is either amp or a song (I guess the amp who would make a song where vocal is sterowise less loud in one ppeaker?)
npxavar
329
113
570
This is channel imbalance in the amplifier. You can use the "balance" knob to fix it. Low volume creates imbalance for cheap volume control pots.
WayneKerr
1,103
1,009
3,070
Is this on only one track or across all tracks?
dommaku2
44
12
45
I don't know what happened
I started thorough testing of my hi fi again this time on TIDAL and sound is great now. My wife also said its better.
I suspect
- old cables were faulty
or new DAC went through warm up period
Or TIDAL is better than spotify / apple music hmmm
dommaku2
44
12
45
Tidal is perhaps better, Quboz is also.
DACs don't warm up....
I have impression it's Tidal indeed. Testing now back and forth. It feels it reduces some harshness that I used to hear, sound is more velvety, fuller at same volume. I don't get tired, it's enjoyable. I got impression Spotify is tiring. Like same song wind of change by Scorpions and other.
The difference is very subtle, its like same song with some very fine detail there that makes the difference.
wow now checked Modern Talking Album all songs in Master in Tidal vs regular Spotify - Tidal so much more Exciting, Full mmm pleasure
dommaku2
44
12
45
I have tested using Spotify Premium via Web Player
- as I am reading now web is 256 kbit/s vs app 320 kbit/s
npxavar
329
113
570
Can you test what is the performance of your system with the Spotify app and sound quality set to "Very High" (this is 320kbps)?
rainsoothe
871
416
19,270
The Aria 906, much like the BR03, would be waisted with an amp like the AXA25. The Nad suggestions are great, also an Arcam (maybe sh FMJ A19 or A29) or the Creek Evo 2 suggestions are all very good. A used Roksan Kandy K2 or Caspian m2 are also well worth looking into.
Also, I'd partly blame it on the DacMagic.
