Feb 21, 2016
My wife wants me to buy those speakers because she likes the design, since they are better then the ones I have, I 'll go for that!
I want to upgrade amplifier, too, what do you think of Abrahamsen V2 UP ? Since those speakers have big woofers I guess they need a lot of power (current)...
Al ears
Moderator
Those speakers are old, maybe 80's and quite inefficient (86dB and 4 ohm) and were suggested for use with amps 25-150watts.
Be wary of the foam around those woofers disintegrating.
That seems a lot of money to spend on an amp to drive these cheap old speakers.
Electro
43
The Abrahamsen V2.0 up will drive any speaker you care to chose easily, and those speakers will sound the best they can possibly be. *smile*
Feb 21, 2016
The foam is new, but I know I will have to switch it every 4-5 years.
Maybe that ampli is too expensive, but I want a good one, the one that can make those speakers sound best with that budget. Any suggestion of a cheaper powerful amplifier?
Vladimir
220
I had the AR-11B and I can tell you from experience you will need an amplifier that can drive the 2 ohms impedance drops. At the time I used Harman/Kardon HK6900 and it worked extremely well.
Abrahamsen, Electrocompaniet, Harman/Kardon, Haffler, Adcom, Bryston would be on my list.
Feb 21, 2016
Vintage + Modern Design is what make beautiful and warm some houses. But who cares, as long as those speakers are bigger and sounds better then mine :) . I will re-sell them as soon as my wife changes her mind, but going forward
One step beyond.
Blacksabbath25
289
77
10,970
If it was me I would buy the abrahamsen 2up as you have to think of the future too just in case you change them speakers for something better or harder to control the abrahamsen will run any speaker
Al ears
Moderator
Agree if you have the cash, and I don't know what the Abrahamsen costs in euros, but you cannot get much better for the money allegedly.
Your wife has taste sir. :)
Feb 21, 2016
I am afraid Abrahamsen does not have enough power, is there anything as good but more poweful in the same price range?
thanks!
Electro
43
thanks!
There are more powerful amps than the Abrahamsen for a bit more money but they are probably not as good imo .
The Abrahamsen V2.0 is far more powerful than the 70wpc suggests with transient power of over a kilowatt and a massive amount of current delivery, it should go plenty loud enough without any distortion .
I can't think of anything else for the same money that comes even close.
Give Colin a call, he might be able to demo one for you .
http://www.iqspeakers.co.uk/?gclid=CJfq-7nu9MgCFSoEwwodtMEDOQ#!abrahamsen-audio/ckbj
Blacksabbath25
289
77
10,970
thanks!
+ 1 there is plenty of power on the Abrahamsen 2up
Al ears
Moderator
thanks!
No idea where you got the idea it doesn't have enough power from. Are you planning an outdoor rock concert?
radiorog
54
If enough power, I've not heard of a better amp at the price. Which country are you in?
Feb 21, 2016
I live in Italy. The person from whom I would buy those AR speakers used them with:
pst140+audiophile 100 esoteric grade
accuphase e-202
pioneer sa-9900
marantz 1200b
all of them have more then 100w, thats' why I was wondering.
thanks
drummerman
540
thanks!
Really?
ASK THE COMMUNITY
