best way to clean piano black
scene
If you just want to remove dust, use an anti-static feather duster.
To actually clean, you could try an ultrafine and soft microfibre cloth - I mean a lens cleaning one, as no-one wants to scratch their glasses - and lens cleaning solution.
chebby
1,257
34
19,220
I'd leave out the lenses cleaning solution!
An old, well washed, soft, cotton T-shirt cut into pieces (no seams, hems or labels to scratch anything). Use a lightly dampened* piece to clean off any marks and a dry piece to 'buff it up' afterwards.
Then a feather duster in between times to scoot off loose dust.
*use a thoroughly rinsed out spray bottle to spray water onto the cloth - not the hi-fi surface - to lightly dampen it.
scene
I only siggested lense cleaning solution as it doesn't leave any (visible) residue - though distilled water would probably be as good. I just have lense cleaning solution lying around, as they give me little bottles of the stuff every time I take my son to the opticians...
And yes, I should have said, wet the cloth not the hi-fi :silenced:
chebby
1,257
34
19,220
Lens cleaning solution is fine on glass (as is Windolene and any number of products with various chemicals and solvents in them), but the finish on a gloss paint or lacquer may react badly.
scene
No that's a fair point, well made. Distilled water it is then.
scene
Joshuamessenger said:
Would use suggest car polish like turtle wax to give a protective layer and then use microfibre rag to buff it and then use the rag to maintain.
As Chebby pointed out - I'd avoid anything with any chemicals in it that could damage the surface finish. Turtlewax contains petrol distillates that could easily dissolve the finish, depending on what it is actually made of.
chebby
1,257
34
19,220
how to go around cleaning my turntable and subwoofer, with out adding scratches
From your REL R series manual...
"Care and Polishing
The cabinets are best maintained by using a spray-on wax, such as an automobile wax made by a company called
Griot’s. If objects are to be placed upon the top, it is advisable to use a small mat to protect the surface and to avoid
the risk of rattles."
From your Project Debut SE3 instructions...
(Click here for clearer picture.)
simonlewis
590
Avoid buying anything with piano black in the title as i have a piano black tv stand (glass) & it attracts dust like a magnet, the only advice i can give is get the wife to clean it on a regular basis or hire a cleaner. :)
AEJim
82
22
Depends on the type of Piano Black it is, it can vary from a glossy vinyl wrap to full automotive quality multi-layer lacquer. On our piano finished speakers we always use Colour Magic (the car wax) of the relevant colour for the best shine before we box them up.
BigH
125
10
18,595
I don't think it is the black that attracts dust but it will show it up, some speakers you don't have much choice ie Kef LS50s.
matthewpiano
Firstly, we don't even use the term 'Piano Black' in the piano industry. It is a peculiar term, especially as the shiny black finishes on most speakers and hi-fi equipment are quite different to what is actually on a real piano unless you are dealing with really good quality stuff.
Secondly, shiny black finishes will always show polishing swirls over time. This even happens on £120,000 Steinway grands with really good quality black polyester finishes. It is simply the nature of the beast, no matter how careful you are.
A soft, dry and clean cloth is the best tool, with careful use of an alcohol-based glass cleaner, sprayed onto the cloth and not the surface, where necessary. It isn't advisable to use anything harsher than that.
MajorFubar
690
8
Surprised absolutely NO ONE so far has suggested the blindingly damn obvious solution that I use: car detailing spray, such as Meguiar's Quik Detailer.
And use a good new microfibre cloth, not some knackered old cotton T-shirt that could easily cover the lacquer with 'cobwebs' and swirl marks.
Joshuamessenger
11
Quote from REL “Combining 13 coats of carefully applied lacquer that sees hand sanding, then hand polishing to a gleaming finish" I believe this to of good quality and not a wrap.
I’m not sure what my turntable is lacquer or a vinyl wrap
I’ll take on your advice and travel to the local Halfords and buy
Meguiars Ultimate Detailer or Turtle Wax Colour Magic
Overdose
279
It's not something I've ever given any time to consider. I don't sit close enough to see the dust, never mind any minute 'swirl marks'.
Any duster will do, but a microfibre cloth should be soft enough.
I wonder how many people on here are so precious about a much larger investment, ie their car?
fpeepingtom
On the Monitor Audio website they recommend "Mer" car polish or T-cut finished off with an anti-static duster, to clean their range of piano black finished speakers.
Overdose
279
Some of these replies are verging on the obsessive. Under what conditions are some of you guys using your speakers that require the use of abrasives (polishes)? Suggesting the use of such products also implies that the speakers are perhaps being mishandled in the first place to require it.
