Best Speakers for the amps
Kawal
13
Hi all,
Needs some advice. I am looking to purchase either a Naim Unity Atom OR the combo Cambridge Audio CX81 and Cambridge Audio Streamer CXN (V2). What type of bookshelf speakers would compliment these two systems. Advice on the best speaker cable would also be appreciated
Regards
KS
Gray
Suggestions will follow. You must listen to decide.
If it was me I think it would be the CA combo.
Speakers would be on stands (not any shelf).
Cables: I'd make my own using minimum 2.5mm pure copper conductors and gold plated banana plugs.
Alternatively, when buying the system, a dealer may be happy to provide cables at no extra charge.
Deleted member 116933
Hi all,
Regards
KS
The saying, how long is a piece of string, comes to mind.
Tbh that's a very big question, and there's normally a budget involved. Size limitations so and so forth
If it were me, id go and listen to speakers you like the look of and then pair the amp/streamer combo to them rather then the other way round
You may find your speaker selection doesn't like either combo.
You have your usual suspects KEF B&W PMC and Cambridge's own speakers
Id look at revel (if budget allows), Klipsch and neat
Deleted member 188533
I agree with this. It's just backwards to me to match speakers to an amp.
Kawal
13
Many thanks
Reactions: Al ears and Gray
nopiano
1,062
721
20,070
That’s interesting, because I’d invariably say match speakers to the room, and then find a suitable amp to power them.
As sometimes said when asked for directions - it depends where you’re starting from! That’s perhaps the case here.
ASK THE COMMUNITY
