Question Best record production for Hi-Fi tests
It has always been my view that when you listen to equipment the judgement that you make should be on the basis of whether what comes out of the speakers is close to what you would hear at a live performance (taking into account listening conditions etc.). Hi-fi is short for high fidelity and fidelity means truthfulness. So hi-fi should be true to the original.
I've also always been of the opinion that it is easier to make these judgements when you are listening to "simple" and "pure" music. By that I mean single voices and single instruments. So when I audition the things I use are in large part of that type. I must confess that i audition very rarely, the last time was 2014, and I haven't changed my equipment since. I posted here about that process then and my list was as follows:
  • Bellini – “I Capuleti E I Montecchi” DG 00289047708031
  • Shostakovich Symphony 5 RPO Ashkenazy – Decca 421 120 2
  • Grieg Lieder Von Otter – DG 437 521-2
  • Dowland Lute Music Vol 1 – Naxos 8.557586
  • John Armatrading – Classics – AM 982 3506 – Track – “Love and affection”
  • Shostakovich Piano Concerto 2 – Leonskaja – Apex 8573 89092 2
  • Joan Baez “Joan Baez” – Vanguard 79594 – Track – “John Riley”
  • Jimmy Hendrix – “Experience” – MCD 11692 – Track - “All along the watchtower”
  • Brahms Piano Concerto 1 – Grimauld – DG 479 1058
  • Beethoven Violin Concerto – Faust – HMC 902105
  • Tallis – “Spem in Alium” – CDGIM 006
  • Cream – “Wheels of fire” – Polydor 531 812-2 – Track – “Those were the days”
I won't bore you with details of this music as it probably won't be stuff you like. However, as an example, the Dowland Lute Music is just a guy playing a lute. Each note is pure, or should sound pure, and you should hear the player's fingers moving on the strings. If the notes aren't pure don't buy the equipment. That's a tough test!
There are other things to look for such as dynamic range. Most "popular" music has a very limited dynamic range, indeed a lot of it is highly "compressed" to make it more suitable for listening in noisy environments. Even in the classical world this happens with, for example, Classic FM heavily compressing their output as their listeners often listen in their cars and other noisy places, BBC Radio 3 uses a much lower level of compression. As a classical music lover I need equipment that can handle a huge dynamic range which is why a piece such as the Shostakovich Symphony 5 is on my list as it has huge range from almost silent to "knock the walls down".
I've rambled on a bit here for which I apologise. To keep it simple, if you have heard some music you really like live use a recording of that as your test.
Whilst I appreciate what you're suggesting but the reality is if you heard it live in one venue, it could sound completely different live at a different venue where acoustics, speaker placement and situe of sound engineer (which will affect how he hears / mixes it) will likely have a far greater variance than between typical home listening rooms.
That aside, unless you're only listening to live recordings the studio version is going to be completely different again, and probably with a different sound engineer and both will be using so many effects from basic EQ, reverb, compression, gates and a whole abundance of other effects to deliver what the sound / mixing engineer deems to sound best.
I set up / recorded my drums years ago and it sounded horrible. My brother in law who does shed loads of mixing / recording came round and in 10 minutes he'd complete changed my awful, harsh reality of what sounded like standing next to an unmiked / unamplified drum kit into what you'd hear on any record ... and they're completely different sounds.
Honestly not meant to be critical but I just don't see them as the same and just my 2p's worth.
My music library is composed of many different genres, from jazz to electronic, folk to pop, rock (...).
One of my favourite bands is Radiohead, which is also one that has released albums with a very high production quality.
Having said that, if I had to choose one single album for testing equipment, I would have to go with Daft Punk - Random Access Memories.
In terms of production, this album is to me as close to perfection as can be: incredible dynamics, clear and clean punchy sound, and a very controlled and complete frequency range.
If you had to choose the perfectly produced album, what would it be?
Rather than than the perfect album, just go with recordings you know. Not just how it compares to what you are used to, but can you hear things you haven't heard before, can you not hear things you normally hear? Are you getting sibilance?
On the subject of hearing something for the first time on a recording: Many years ago, I went with my father to listen to some hifi equipment, he was getting back into it after 20 years. We were in a listening room when the man from the shop checked in on us, he could tell there was something wrong. We were listening to one of his favourite classical CD's, he explained said there was a strange "whooshing noise" just audible. The man explained that was a train on the Piccadilly line, and quit common on a lot of recordings. He then pointed to another CD in a stack and said if you listen closely to that one you will hear a whoosh and a band when a door is opened in the studio.
I believe the old Kingway Hall had an underground train running underneath, and you can hear the rumble on some recordings. Iirc it was used in particular by EMI in the 1970s.
Reactions: Fandango Andy
I believe it was Kingsway Hall, this was back in the early 90s so still in use at the time. I understand the stopped recording for the rumble, but the whoosh wasn't that noticeable so they let it go.
Reactions: nopiano
I agree to a certain extent. I mainly listen to classical music and a lot of it is recorded live or in a concert hall where a live performance would take place. Of course with classical you rarely get to hear the same performers live and on a recording. Nevertheless the best recordings are in my opinion the ones that come closest to the sound you get in a concert hall. It's all subjective of course!
PS Some of the finest classical recordings come from the old Mercury "Living Presence" catalogue which in its stereo days used just 3 microphones in a concert hall. Sadly I think they are not available anymore.
Agree, never had a duff Living Presence LP.
Speakers Corner discs are also excellent.
I rcently purchased a new CD player. The first album that went in was WOTW's, then Animals, then Richie Havens. One track brought a tear to my eye. Is this what OP was looking for? I too have the Daft Punk collection.
Sorry I'm late.
IAN.
Sorry I'm late.
IAN.
what CD player; I am looking for one and if it brought a tear to your eye, it must be good !! ??
I know I am late again. I find it hard to describe my inner feelings. So I will try to tell you what happened. When I was saving for a new amp, I noticed a SACD for sale. It was offered at a good price. And just by instinct, I went for it. It is the MARANTZ SA-10.
For me, it turned out to be a revelation. I'm not a true audiophile, I cannot compare it with other players, as I am totaly unqualified.
But It is like getting a new head. They should be handed out to school leavers, with some decent headphones.
PS I drink too much.
IAN
IAN
That is one hell of a reference player, Ian 👍 Lusted after one of those for many years but was out of my price range so had to settle for the Ruby, which I have found to be excellent and is now part of my end-game system 🤞
Having read this back in December I finally got round to listening to this via Spotify and have now bought the CD.
I have to agree. It sounds great!
