Hello,
as the title says I'm looking for IEMs under 100€ to only use with my phone and maybe sometime my laptop. I don't use a dac, just straight from the 3.5mm jack of my pixel 3a.
I stream music from Tidal HiFi, I need these only when I'm going around outside (for the future since I'm stuck in quarantine) and I need a portable solution. I already have a pair of AKG K712 pro with a JDS Atom to use at home and a pair of Sennheiser Momentum to use like when travelling.
Wired or wireless is the same, but I'm 99% sure I'll get a better value from wires. Since I mainly use them with my phone I need a mic since it's way more convenient for calls.
IEMs + a replacement cable with a mic are accepted as well, as long as the total is still under 100€
Thank you!
Thank you!
