Best Freeview TV Recorder 2018?
Strictly Stereo
I need to source a Freeview recorder for my father-in-law. No fancy bells and whistles required. Just a simple interface which will all him to record and play back terrestrial TV. He will be using it with a Panasonic 32" TV with HDMI inputs and support for at least 1080i, possibly 1080p. He probably does not need a vast amount of storage. What's good?
Gray
1,986
1,351
13,570
I've bought / installed several Humax boxes for people over the years, mostly buying new.
I've also bought refurbished direct from them as they're almost literally as good as new and guaranteed. Have a look here: https://www.humaxdirect.co.uk/refurbished.html
That 2000T looks like a bargain for £99, its 500GB HDD allows for more than enough recording - for a light user (125 hours of HD)
Although Humax are about as user-friendly as they come, I have found that some users do still find them a little involved.
(Maybe download some manuals first if you're going to be explaining the operation!)
Craig M.
127
We’ve got a Humax youview one, it’s pretty decent although it does seem to become a little unresponsive every now and then unless it gets switched off completely and restarted occasionally - maybe once a month or so.
Strictly Stereo
Thanks to you both. Despite what I said about "no bells and whistles required", I think I might try him with a refurbished Humax DTR-T2000 Youview box.
abacus
586
299
19,270
If you have CEX, Cash Convertors or similar shop in your area pop in, as they usually have a selection of traded in boxes for not much money. (I picked up my BT Youview box for £15 a couple of years ago)
Bill
GeoffreyW
155
9
18,595
This may be a step too far, but look out for the Panasonic DMR series of Freeview recorders and they are also Bluray/DVD players. Simple to combine with Panasonic TVs - I have two pairs on the go. I find them reliable and easy to use ( I'm in my 70s).
Mine are DMR-BWT720 (1TB) & DMR-BW780 (250 GB) machines, had them a few years, so used prices should be reasonable.
ASK THE COMMUNITY
