best fans to use
markyboy156
203
hi all
i have just bought new components to buy a pc
the components are
i770k cpu
asus prime z270-a motherboard
corsair vengeance led 32gb ddr4 3444 ghz memory
corsair h100i v2 liquid cooler
samsung 960 evo 1tb ssd
wd blue 6tb hard drive
evga geforce gtx 1080 ti graphics card
windows 10 usb flashdrive
pioneer bdr j11sk writer
lg bh16ns55 writer
silvetstone primera rgb case
logitech g900 mouse
corsair k70 rgb rapidfire keyboard
my question is i am after buying fans for my silverston primera rgb case i want very good quality fans that will keep my componernts that i bought very cool what would be the very best fans to use and how many could i use in the case taking into account the componnts im using
also what high quality rgb cables would i need to connect all of the components together to connect all ther componets together to get the pc fully up and running can you list specifically what good quality cables i need
abacus
Power supply will come with all cables
Motherboard will come with a number of cables, though you may need to but a few extra SATA cables. (Couple of quid from the place where you get your PC parts)
CPU Heatsink/Fan will have its own cable
Case sockets also come with cables + they usually include fans
However, as you need to ask these questions, I strongly suggest you buy one pre-built and setup for the job in hand, (Most dealers will allow you to choose your own components and then build and set it up for best performance) as otherwise there will be little chance of you setting it up for best performance.
If you still want to do it yourself, get a book on building PCs, and read it before ordering any components.
Hope this helps
Bill
abacus
Here are 3; however, if you do a google search you will find many others.
https://www.scan.co.uk/
https://www.novatech.co.uk/
https://www.overclockers.co.uk/
The number of fans will be determined by the number of headers on the motherboard (It will be in the specs) and the number of spaces in the case.
More fans do not mean better cooling, but using the correct type and combination (Which includes the type of case) will. (Hence the reason I say let the professional build it)
Another point is that just specifying best buys or 5 star rated products to include in the build, may not result in the best performance, (Just like matching 5 star audio products does not guarantee best performance) so take advice from the professional manufactures above.
Hope this helps
Bill
Vladimir
220
7
It's important to maintain flow of air in a set direction. Front fan has to pull in cold air into the case, and the back fan needs to draw the hot air and push it outside.
If you put a side panel fan above the CPU cooler, it needs to draw the hot air from inside and push it out.
You can buy a PC case with all fans preinstalled, just plug them in to the mobo and done.
Alantiggger
274
33
18,920
No idea as to what games you want to play but over all, your set up will be decent for future upgrades and maybe a 'little' on the OverKill.*wacko* ... lol.
Learn to play whatever games better and upgrade as you move on (get better)
