Oran said:Hi there,
Which DAC would folk recommend for a PMC twenty 5 24 and Bryston 4B cubed system?
Playback is from a mini Mac running J river.
Has anyone got any relevant DAC experiences that they could share?
Thanks,
Electro said:One of the Bryston Dac's would be logical .*smile*
I wonder whether this post will actually appear. *nea*
ellisdj said:Gazzip - can you tell me about how the Bryston amps have improved over the time you have owned them.
The spec on them seems similar i.e. sst to sst2 reads the same however I reda before that the SST2 is more linear in its delivery ie. better from a lower volume, where as the SST sounds better when you turn it up.
Then we have the cubed range which has some extra circuitry to remove any noise present but that doesnt tell the whole story.
Oran said:Thanks for all the replies.
In answer to the questions:
the budget is whatever it takes to get a dac that best compliments my system with going too over the top.
If there are going to be any improvements in sound quality then I'm open to an analogue pre amp/volume control. However I like the idea of a dac that also acts as a preamp/volume control - keeps things simple.
I listen to all sorts of music though mostly rock and pop but easily could be folk, jazz classical etc.
Thanks 🙂
NSA_watch_my_toilet said:Thank you for your remark Gazzip.
Qualify as "Stink", the opinion of peoples don't sharing your views after your tests suits you.
Please, share with us just a little bit of your test results/protocols with a link. it would be a nice gesture for us. Please feel free to consult the research page of the BBC laboratories for having a written confirmation of my return of experience (you need to pay a fee for reading the articles, it will helps the UK economy whatsoever). You will have same response for tests done at Deutsches Rundfunk. Feel free to e-mail them for calling their studies as stink "because you heard it".
drummerman said:Is it possible that you can now buy a DAC for next to nothing which is as good subjectively and on paper as the very best esoteric high end ones?
Most manufacturers are implementors only rather than developers or dac engineers, a few exceptions.
Even ESS's 'super dacs' now appear even in the cheapest sub $150 products.
If the implementation is done correctly and the output stage is carefully done, I can't see why such a DAC can't be done very cheaply.
HIFI NEWS & RR'S measurements often show that expensive DAC'S are on occasions badly engineered or sometimes voiced to sound a certain way.
To build a good amplifier or speaker costs a certain amount of money but does that really hold the same with DAC'S nowadays?
No relevant experience of it, but Bryston's own DAC, which I think they call 4b3 might suit. It is obviously an engineering match but you'd need to check connectivity.Oran said:Hi there,
Thanks,
nopiano said:No relevant experience of it, but Bryston's own DAC, which I think they call 4b3 might suit. It is obviously an engineering match but you'd need to check connectivity.Oran said:Hi there,
Thanks,
The only serious alternative I'd investigate is whichever Chord model fits your budget, maybe the Hugo TT? This neatly leads into where this thread has moved, and I think my answer to drummerman is that the chips are indeed very good, but I have a hunch - and no more - that how they are implemented can make a difference (e.g. Old fashioned things like good power supplies and careful wiring internally). The real step change is to Chord's model of programming your/their own DAC, and I have seen one or two manufacturers doing the same, though off the top of my head I can't name them.
Hi gazzip, now that you mention it...! Yes, thanks, they are one, and you remembered the acronym that escaped me. (I try to avoid googling my answers)Gazzip said:nopiano said:No relevant experience of it, but Bryston's own DAC, which I think they call 4b3 might suit. It is obviously an engineering match but you'd need to check connectivity.Oran said:Hi there,
Thanks,
PS Audio are also doing FPGA.
NSA_watch_my_toilet said:The opinion you have Sir is, in your case, and for the moment, invalid. Because you need to do things a certain way to have results that are valid. Only the way you do your testings is determinant for the validity of your opinion. I could go try speaker under water and claim all speaker sound bad and try to kill peoples. It would be my opinion, it would be true, but wrong from the method I used to come to this result. So is your statement. For the moment, you shared no feedback of your test result or gave any proof that any kind of methodic approach was used.
We don't even know if you ever tested out the DAC you claim to have listened.
And the way you brought your point disqualified you. You dropped in with harsh words in trying to look smart. Please show us now that you are.
I will not speak with you too long about the way you try to make me look like somebody that didn't try the things by himself. Desperate move of a desperate persons trying to be right in a discussion he can't win.
NSA_watch_my_toilet said:Please feel free to consult the research page of the BBC laboratories for having a written confirmation of my return of experience (you need to pay a fee for reading the articles, it will helps the UK economy whatsoever). You will have same response for tests done at Deutsches Rundfunk. Feel free to e-mail them for calling their studies as stink "because you heard it".
