Best DAC for my system help for short list please
Leehallam
37
I would like to buy a DAC to go between my Sonos ZP90 and my Roksan Caspian M2 amp any advise or suggestions please before I go shopping. I am sort of between the Rega and the Audiolad Mdac.
Thanks for your help.
Lee
acalex
73
Leehallam said:
I would like to buy a DAC to go between my Sonos ZP90 and my Roksan Caspian M2 amp any advise or suggestions please before I go shopping. I am sort of between the Rega and the Audiolad Mdac. Thanks for your help. Lee
I think the usual list in the price range 300 - 800 eur is the following
- Arcam rDAC (cheapest)
- DAC Magic Plus
- Audiolab MDAC (most expensive)
- Rega DAC
- M1 DAC from Musical Fidelity
Try to go and listen yourself at the different options before buying anything...
Leehallam
37
I have been for a listen to the, Rdac, music fidelity m1 and the vdac and then the rega. The rega was the best for me hands down so the dealer kindly let me bring it home for the weekend so listening away now on my system at home even done a blind test with the wife and she can tell the differance. The one thing that is bugging me is I could not get a listen to the audiolab Mdac. So this is mt dilemma do I buy the rega I am pleased with or do I buy the audiolab blind based on the reviews and get the headphone output that I could quite fancy. Any advise or any dealers that have a Audiolad Mdac I could home demo.
Leehallam
37
Can anybody who has auditioned both the Rega and the audiolab help with some advice or a comparison please.
Thanks Lee
acalex
73
Leehallam said:
Can anybody who has auditioned both the Rega and the audiolab help with some advice or a comparison please. Thanks Lee
Not sure if you need high-resolution on USB...in that case forget about Rega as that's limited to 16/44
It is very difficult to get hands on the new M-DAC as it's out of stock almost everywhere. I think you should give the MDAC a try before deciding. You will get headphone stage and pre-amp included in the package
You didn't try the dac magic + ?
Shanka
123
I am about to start looking for a new dac, currently have a dacmagic which is run through an AV system and am very happy with it,and have got it down to the rega or audiolab which I am looking to demo in the next 6 weeks.
When you demo the dac's do you take your own computer or does it not make any difference, I don't think it would do but I'm not sure.
I am interested to see how you get on as we have the same amp, my experience of audiolab is lots of detail but little warmth and have very little experience of rega products but they seem very popular here.
Looking forward to your findings,
Good luck.
The_Lhc
1,176
If it's just for the ZP90 it won't matter, it only goes up to 16/44 (and isn't USB, obviously!).
acalex
73
True, didn't realise OP mentioned in the first post! ;)
Pedro2
70
31
18,570
If you want more 'warmth' then I'd also recommend audio gd. Only problem is that they're chinese and virtually impossible to audition. I read numerous reviews and was torn between rega and audio gd nfb2. An Australian guy called john darko is worth googling as he does some excellent, very detailed reviews of kit and rates audio gd very highly.
I'm very pleased with mine. Its fed from a squeezebox touch and the sound is excellent. Loads of detail but not clinical at all. Very full bodied too. I'm sorry but describing the sound of dacs is not always easy! One last point - it's built like the proverbial outhouse. Weighs a ton with serious power supply. Not the prettiest piece of kit either if aesthetics are high on your list.
Leehallam
37
I now have at home the cambrige dac magic plus, I have a audiolab 8200cd to try the dac on I know it is different to the Mdac but I am told the sound character is the same and I have also brought back the rega dac. I was very surprised how much kit the dealer let me borrow. So I am going to spend the next few hours playing.
Lee
acalex
73
Leehallam said:
I now have at home the cambrige dac magic plus, I have a audiolab 8200cd to try the dac on I know it is different to the Mdac but I am told the sound character is the same and I have also brought back the rega dac. I was very surprised how much kit the dealer let me borrow. So I am going to spend the next few hours playing. Lee
Nice one! Let us know your findings...for now Rega is the one to beat, right?
SteveR750
730
137
19,070
I found the dacmagic plus works well with the M2, though I haven't tried the Rega in my system (and don't want to, in case it sets off more impulse changes) so can't compare.
Leehallam
37
Testing finished
Decision made I went for the Rega dac was better for my ears natural warm sounding vs the the other 2 I am pleased I did so much testing. On the negative side I will now need to buy a USB to coaxial interface for the 24 bit stuff v llink for £100 sould do the trick. All good dacs but rega was the one for me.
Thanks again for your advice and help.
Lee
acalex
73
Leehallam said:
Testing finished Decision made I went for the Rega dac was better for my ears natural warm sounding vs the the other 2 I am pleased I did so much testing. On the negative side I will now need to buy a USB to coaxial interface for the 24 bit stuff v llink for £100 sould do the trick. All good dacs but rega was the one for me. Thanks again for your advice and help. Lee
Great. You won't give the MDAC a try also?
Leehallam
37
My dealer could not get the Mdac for another 3weeks and I was happy with the Rega so my impatience kicked it I have bought it and it is playing away now.
Thanks Lee
acalex
73
Thanks Lee
OK, well done. I am curios to see what this MDAC can do as it is almost impossible to find aroun here also (Belgium).
