Be kind,please....
Hi,this will of been asked a thousand times,but here it is again!!
Could someone please tell me the correct way to connect my TV,Sky HD,BluRay and AV amp,correct as in,which type of cable connects what to what.Please keep the answer as simple as possible,like wot I is!!
Kind regards,Richard
Andrew Everard
1,878
It will depend on what your components are: give me some model numbers and I'll give you a step-by-step - yes, on a Bank Holiday Monday evening!
Gerrardasnails
295
Bangitontop:
I'm guessing you have an AV amp with hdmi. If so, HDMI from screen to amp. HDMI from Sky HD to amp. Then either coaxial or optical (depending on which your Sky box has) to amp for surround sound. And HDMI from Bluray player to amp. If your amp decodes HD audio, you will get HD audio and picture through the one HDMI cable. You only get stereo sound from HDMI with a Sky HD box.
Andrew Everard
1,878
Indeed - that would be what I would advise, but I've been through too many of these 'how do i wire it up?' routines not to know that assumption is the mother of confusion...
Ok ,potential set up,Panasonic TX32LZD85,Sky HD,Panasonic DMP-BD60 and Sony STR-Dg820.
Cheers,Richard
Thank you both very much,I will be able to sleep tonight!
Cheers,Richard
ASK THE COMMUNITY
