unsleepable
- Dec 25, 2013
- 6
- 0
- 0
danielcollins90 said:I think I may get the NAD as that ticks every box and shelve the idea of a CD player, I want quality and if I can get that from a good FLAC copy then I'm happy to get that that way.
If you decide to get the NAD, I'd make a point to audition it first with your speakers.
If you intend to use it as a full integrated amplifier, be aware that it has much less power than you current system, and it may not be a good match for your Monitor Audio BX5—the D 7050 has less power than the minimum recommended by Monitor Audio for these speakers.
Also, people in this forum have posted mixed reviews about the DAC of the smaller amplifier of the series, the D 3020.
If you intend to add the D 7050 to your current setup, take into account that it only has preamp outputs, which likely imprint a voicing to the sound—more so, given its choice of amplifier section.
It'd be great if there were more opinions in the forum about this amplifier.
