FATS 2828 said::bounce: Before commiting A small fortune will my yamaha as 2000 amp, At a 100 Watt,s per channel be sufficient ?
FATS 2828 said::? So b&w specification . recommended amp. 30-100 watts inti 8 ohms is not a true guide ?
Also yamaha,s specification of 100watts rms into 8ohms is not a true guide ?
Comatibility eh ! :wall:
FrankHarveyHiFi said:FATS - only those who have heard the PM1's with your Yamaha amp can comment on how well it will drive them. Who hear has heard the combo? Please stand up and pitch in if you have. Thought so....
FATS 2828 said:Many thanks erwin and rick
FrankHarveyHiFi said:Unfortunately, specs don't tell the full story - it's how things actually work together in practice. The amplifier recommendation is a general one, and not one that should be strictly followed to. No manufacturer can give solid facts about the amplifier specs that can be used with their speakers - notice B&W mentioned 30-100w "on unclipped programme". There will be 30w amplifiers that will drive them, and other 30w amplifiers that won't, not properly anyway. Other factors will be room volume, and the required volume level. Many amplifiers will drive these low sensitivity speakers quite well to the ears of most, but there'll be a lot of amplifiers that will actually be struggling to reproduce the transients in many types of music. When amps start to struggle, things get rough and edgy, and begin to sound compressed. I've been hearing the PM1's gradually running in on the end of the Cyrus X300 monoblocks, which have more than enough in reserve to let these speakers do what they're designed to do. Because of this, I'll know straight away whether an amplifier is doing a good job or not. Anybody can hear the difference between a speaker driven well or not so well by trying an amplifier with a better quality output. I've been making the point for a long time on this and other forums that if a speaker isn't driven properly, it's not going to sound it's worth.
