As I’ve been trying to explain in on one of the reviews, Watts tells you nothing, it can be measured in a multitude of different ways each giving a wildly different result.
One way to figure out how powerful your amp is, is to look at what happens to the watts as Ohms drops, as the Ohms halves the power should double (correct me someone if I’m wrong) so:
-> 8 ohms = 150 W
-> 4 ohms = 300 W
-> 2 ohms = 600 W
Most amps will not get anywhere near this, but the closer you get the better. One thing to watch though is that as the power rises so will the distortion, and you may also get other effects such as a compression or a narrowing of bandwidth.
As you can see it's a nightmare, sometimes it's just better to try it and see if the sound goes bright, harsh and edgy. Be careful though as this can damage both the speaker and the amp.
Power does not guarantee quality of course, I had an professional amp that could put 1.6kw into 2 ohms, sounded shocking though.
Determining how hard a speaker is to drive is harder still as the 'ohms' rating is an average, and sometimes a downright guess. It may say 8ohms but may drop way way below that, and that will kill a lower powered amp.
Hope that helps 🙂
