mini66 said:Hi,
I was told in the views here at What HiFi that B&W CM8 speakers need carful pairing...I have a Naim SuperUniti all-in-one and wondering if it was a good match? Thanks
mini66 said:I have heard the CM8's linked to a Naim system and like the sound, but then I read you have to be careful with pairing amps with the CM8's...why is this?
mini66 said:Hi,
plastic penguin said:mini66 said:I have heard the CM8's linked to a Naim system and like the sound
With respect if you like the sound, why the question?
Sliced Bread said:Sorry about the spelling errors above. I'm posting by phone.
Sliced Bread said:I have the cm8s and I would agree that you need to be careful when matching the speakers to an amp. Thr treble I n the cm8s can become a litle dominant at higher volumes when used with a bright amp, however it really is personal opinion. I use them with an amp that's just on thr warm side of neutral and it balances out quite nicely, however ive also heard them with the Roksan Kandy (which is not in itself bright), but the treble sounded quite hard. With that said, I knwo of a few people who use them woth bright amps and they really enjoy the sound. I not familiar with your amp, but if it is very detailed then you might want to listen to the combination over a long period of time (preferably home demo) before you buy. Itvmight be exactly what you need, but it may also be death by detail and become fatiguing over time. Enjoy.
I've not heard the combination myself, though I understand that the supernait has quite a bit of current so I'm sure it should easily be enoughmini66 said:Sliced Bread said:I have the cm8s and I would agree that you need to be careful when matching the speakers to an amp. Thr treble I n the cm8s can become a litle dominant at higher volumes when used with a bright amp, however it really is personal opinion. I use them with an amp that's just on thr warm side of neutral and it balances out quite nicely, however ive also heard them with the Roksan Kandy (which is not in itself bright), but the treble sounded quite hard. With that said, I knwo of a few people who use them woth bright amps and they really enjoy the sound. I not familiar with your amp, but if it is very detailed then you might want to listen to the combination over a long period of time (preferably home demo) before you buy. Itvmight be exactly what you need, but it may also be death by detail and become fatiguing over time. Enjoy.
My SuperUniti has 80w is this enough to get the most out of the CM8's as I heard they require a lot of watts to get the most out of them?
