audiolab to arcam?
audioaddict
114
Hi my previous post was audiolab to uniti my problem is i wanna cut down on number of boxes i have audio lab 8000 monos 8000 cd arcam t32 tuner so wld a swap from monos to arcam a38 amp be a good move my speakers are at present ma rs1 which sound good with the arcam tuner any advice? ?
audioaddict
114
Yeah thought about the neo but again i think the sound quality wld be a step down and certainly less power i do like the look of the a38 the speakets will get upgraded and mostlikely will go for an all arcam set up eventually love the big rich sound
plastic penguin
Please forgive my ignorance, but why do want to change from the Audiolab Monos? Probably pound-for-pound it'll give you better overall SQ than a single Arcam. As I mentioned before I'd look at speakers first: PMC DB1i, TB2is, B&W or perhaps the MA GX range.
Jason36
427
:p
Because as per his original post....."he want to cut down on the number of boxes" :oops: :p
plastic penguin
Jason36 said:
:p
Yes, by going A38 the OP will still have separates, and I think the Arcam will struggle to better the Audiolab monos and pre-amp.
At least if he auditions the speakers I've mentioned they will gel well with both Audiolab and Arcam.
Jason36
427
Jason36 said:
:p
I agree with you on the point of selling the Monos and Pre-amp and replacing with the A38......I think the come down will be very noticeable to the OP, and not in a good way, especially with improved speakers. But of course he would only have one box rather than three.
I suppose it's the same old problem of space vs sound.....and trying to get the first without compromising the second :roll:
plastic penguin
Jason36 said:
:p
Yup, I've been grappling with space Vs sound for yonks...
The only sure way is to audition the A38 against the Audiolabs and decide if it jusifies the downsizing.
audioaddict
114
Yes this is a tricky one as i dont really wanna get rid of the audiolab monos i will try some of the speakers plastic penguin suggested would a pair of bw 684S be a good match? ??
audioaddict
114
Just had a brain wave i cld get an audiolab 8200 cdq there fore cuttin down on the pre amp and cd player thus giving me two boxes less
Diamond Joe
88
6
... my sums say that'll be one box less!!
However, keeping on that theme, how about getting the 8200CDQ, sell your 8000 monos and replace them with an 8200P - that'll drop you down by two boxes. :)
Diamond Joe
88
6
Actually, now I think about it, that sounds like a thumping good solution for my future needs, hmmmm :?
audioaddict
114
Yes one box less thank you do you think the power amp wld be too much of a step down in
in quality good idea though
plastic penguin
audioaddict said:
Or i cld get a 8000p and save a fortune
Using your existing preamp + a power amp would be my suggestion. TBH, no idea how it compares to the monos you have, but hi-fi is always a compromise. If you can't audition that's the gamble you (we) take.
Going back to my earlier post I really think you should look at speakers first: The RS1s are a tiny version of my RS6s. I love them to bits but they are not a good match with Audiolab. The hard domed tweeter is a little too exuberant for the Audiolab's crisp presentation IMO.
Listen to Arcam or Leema and you'll understand where I'm coming from.
audioaddict
114
I totally agree with you the amp n speakers not a gd match. When i listen to my arcam tuner the sound is much fuller and richer which is what made me think the arcam a38 would be a smoother match and also cut down on my box count. You also previously mentioned the solo neo any idea how that would sound with a p38 power amp giving me a powerful two box system? ?
plastic penguin
As mentioned before go and listen and test your own apathy.
We are all experienced with hi-fi but that doesn't we've heard all your combos. We can ONLY advise based on our own experience: What I like and what does it for you could be 'chalk and cheese'.
Hi-fi isn't an exact science.
I was looking for a minimal system and went for the Arcam A38/CD17 combination with Monitor Audio RX2 & Chord Cables. Having owned this system for nearly a year, i can only say what a joy it is to come home after work and listen to music. I tried the Arcam with many speakers but personally found them to work with Monitor Audio the best.
Hope this helps
audioaddict
114
Hi emporio yes thats a great help. When i listen to my arcam tuner it sounds deep and rich through my monitor audio rs 1 and which is ztill tempting me to go for the arcam a38 amp which looks like quality well built kit.
The A38 will continue the warm rich sound matching your tuner. I originally started off with the cd17 which I used with my AV amp & B&W 684. The CD17 was brillient, but found that there was something missing so went down the separate hi fi route, keeping things to a minimum. Anyways a few auditions later walked out with the A38 & Monitor Audio RX2. Also found the chord cables work well with the system.
audioaddict
114
Cool maybe if i did get an a38 i cld keep my rs1s for a bit longer as they sound gd when i listen to my tuner
Andrew17321
24
Warning to Audioadict.
Cutting down on boxes just leaves more room for new boxes. Been there, done it (and improved the sound), and now I am back there.
There is much to be said for having no room for any extra boxes. Maybe wait until it is time for a complete revolution to internet radio, music (maybe HD) on a NAS rather than CD player, etc? Just a thought.
Andrew
CnoEvil
556
11
Andrew
:rofl:
You are not wrong!
